I need a replacement flush seal for an embrass peerless dual flush valve. The seal is approx 63mm outside diameter (which seems standard) but with a bigger than normal inside diameter of 40mm. 2mm thick all across the surface. But I can’t fine a replacement!
The fluidmaster replacement (at Screwfix) has too small a hole, and the viva skylo replacement is the right size but wrong thickness.
My local plumbing supply shop didn’t have a match; can anyone point me towards somewhere online or in Bristol/South Gloucs where I can get a replacement, ideally in silicone but I’ll take whatever I can get.
Thanks.
Thanks.
