Hello.
I have a Dual Flush Push Button Toilet flush that is probably 15 years old. No problems at all in the past - one press & the Half Flush and Full Flush release water.
But, about a week ago, the "Half Flush" button stopped releasing water completely &, about the same time, the "Full Flush" button would only work if I kept the metal button pressed for at least 5 seconds.
Eventually the external Full Flush button also stopped working. No water would be released no matter how long I kept the external metal button pressed, even though the tank was filled to the normal level, which I checked by removing the lid.
However, after removing the lid, when I pressed the actual "Full Flush" button inside the tank, the flush worked perfectly; except I had to keep the button depressed for about 5 seconds. Initially, the water only trickles out, but as the water level drops in the tank, the normal full flow of water out of the tank resumes.
But, the Half Flush button still does not release any water, when I tried pressing the button inside the tank after removing the lid.
So, for now, I've just removed the lid & using the Full Flush only without any problems - other than it looks ugly to have a toilet without the lid on the tank.
I'm buying a new Flush Valve & new metal buttons, but just wanted to know if anyone has encountered the same issue and how they fixed it.
Thanks for any assistance.
