we have dual small storage tanks in the attic connected together with 22mm pipe. One feeds the low pressure cold and hot water. Question is that both tanks have a supply and ballcock taken from the common 15mm rising main. Because the ballcock valve in each tank operates slightly differently, when the level drops one valve will operate to make up the loss leaving the other a "dead leg" - consequently freezing up (and causng flooding once already) . Today I removed one side of the dual supply to one of the tanks ie the one with the longer supply pipework that has now frozen twice in the past 2 weeks.
Question - Did I really need a supply to each tank? With large bore pipework to bath: 22mm, and only a single 15mm supply now to both tanks do I run a high risk of "starving" the hot water cylinder??
Any comments appreciated.
