earth loop testers
1 Jun 2005
i have got a hold of an earth loop tester, megger LT5. when i use it tho it trips the RCD. am i susposed to bypass the RCD?
Some testers will trip the RCD. Others are designed not to, you need to check the spec and manual.
The LT5 will trip out rcd's you need the LT6 or LT7 to overcome the tripping rcd during EFLI testing.
If you need any info or user instructions on test equipment I came across the site below
MOD
e mail removed
Errr- that's not a web site, it's an email address...
Cheers,
Howard
Using Test equipment is fraught with dangers, if you do not know how to use this equipment, then you should leave well alone.
