easy to fit a radiator here?
16 Sep 2006
Fife
this is the rear vestibule that leads into the kitchen through a door sized opening. there is literally no wall space in the kitchen for a radiator. would it be easy enough for a heating engineer to install maybe a 40cm single panel radiator to the wall space immediately beside the boiler i.e. to the right of the pics?
Absolutely easy to do - you don't even need a Gas Safe bod because the boiler would just be turned off, drained, filled again after the job. A competent plumber would walk it ( would include dosing with inhibitor and leaving filling loop disconnected)
thanks for replies. no, kitchen isn't possible even plinth style for a number of reasons I won't bore you with.
