I am having problems with some of my windows. The Eclipse window handle is floppy and wont operate the lock mechanism. There seems to be no bite at all.
Ok at this stage the make of handle isn't important, if the handle is just turning and not doing anything then it's either the spindle has fallen out the inside of it or the square hole in the actual locking mechanism that the spindle goes through has disintegrated, you'll need to remove the handle to inspect further, just 2 screws and it slides off
I done that yesterday the problem is inside i think as everything is rattling if i put screwdriver in it. I am guessing the pane has to come out to get inside ?
