Hi guys
Need some help pls.
The above boiler has a hot water issue, ch working perfectly fine.
When you turn the dhw tap on the hot water works fine for about 5mins then it suddenly starts to drop.
I had the dial set to 57c, the hot would come on and go to around 70c then drop to around 55 then back to 70 again, this continues for a few mins then it slowly decreases to 38 and it stays there. Until the tap is turned off and back on again.
I suspected the dhw plate, so I removed it but that was really clean.
The boiler is only 5 years old and has a magnaclean fitted.
Replaced a new pcb, but same issue.
Any ideas would be appreciated pls.
Need some help pls.
