Hi All
As it is starting to get a little chilly now, I just thought that I would give the central heating a run. I initially noticed that the pressure bar was low, 1.1, so I increased the pressure to 1.4.
I put the system on and after about 10 mins all rads were hot and so thought I would turn system off. The temp gauge of the boiler was past the red area and when I checked the pressure on the boiler it said 3.1, I shut the boiler off quickly, as thought that the boiler could blow!! I checked the water inlet valves and these were both off.
After a while the pressure returned to 1.4. When I tried the hot water, which has been on all summer, the pressure bar only went as far as 1.7 and stayed there.
I think therefore there is a problem, as I did not expect the pressure bar to be so high when using central heating, any ideas of what problem might be?
P.S. system has run for last 4 years since installation ok, never noticed pressure this high.
Thanks.
Thanks.
