Help peeps !
Customer has a vaillant 837 and decides they want a pumped shower for their main bathroom (5 bed, two bathrooms and an ensuite)
I fit the cylinder, shower, pump etc etc and then wire in the mid position valve ,cylinder stat, room stat and two channel programmer.
As in the linky http://content.honeywell.com/uk/homes/systems.htm
The problem is the boiler now constantly rotates to fault code s97 s98( flow/ return sensor check is running, demand (DHW or Heating is blocked) preumably the valve is either not opening fast enough or ??? the boiler then sits idle at code s53 .
Please can anyone give me a starting point to fault find TIA.
