efficiency of vented as opposed to closed system?
16 Oct 2015
Can anyone tell me the difference in efficiency between a closed system and vented, ours is vented at the moment and I'm considering whether it's worth altering it to sealed system (expansion vessel, prv and filling loop with guage)
Simply sealing the system will not change the efficiency of it.
If you have a configuration problem causing air to build up in system or some other issue then sealing may help it work better, but sealing it wont alter gas consumption or heating output.
ok thanks, I prefer a sealed system but if there's no difference to the efficiency then I'll leave it as it is
The energy efficiency training, which all engineers were supposed to go on about six years, ago taught us that an open vented system is about 2-3 % LESS efficient as a result of heat loss from the header tank and its pipework. This figure comes from the EST.
The cost of converting may be difficult to recover in a reasonable time period.
But sealed systems should in theory require less maintenance.
Furthermore, in the event of a leak, the water loss is restricted to little more than the active volume of the expansion vessel. In contrast a leak from an OV system will be fed by the float valve and can lose hundreds of litres which can cause considerable damage if not quickly discovered.
Tony
