electric cooker
  • Thread starter Thread starter Tm
  • Start date Start date
Tm
8 Sep 2004
i have just ordered an electric cooker 4 hob and double oven. when i looked at where thew cooker sould go there is a 3 pin plug soket not a white panel for the wire. this plug socket runs to a swich on the wall wich is labled cooker. i pluged a sterio into the socket and it is wired up to the switcher. is this supposed to be like this becuse i dont like it. put a plug on the end of my cooker im not keen on that could anyone help. do i need to have a proper piont put in for the cooker or is a plug socket ok
chers in advance for any advice given
is the switch labled cooker a proper cooker switch
is there a dedicated cuircuit from the CU?
what size cable is it?
its fairly common practice when replaceing an electric cooker with a gas one to replace the cooker connection unit with a socket and if you can confirm this has been done then you should just be able to change it back
You also need to check that the size of cable and the rating of the fuse/MCB are OK for the cooker that you have bought.
You may have to do some work to be able to connect it up....
