Electric Heaters
1 Nov 2012
Northumberland
I need to put an electric heater (or two) into a new rental I'm doing (no gas supply). There is such a variation, the requirements are good heat retention (oil filled?), wall mountable, slimline if possible, 7x24 hour timer and a thermostat... anyone got any recommendations?
The house is tiny, lounge 10x12, bedroom 10x10 (which houses the hot water tank in a wardrobe)), small open plan kitchen 8x6 and a bathroom (which will have a heated towel rail). So really just thinking about a suitable heater for the lounge.
Note: the house is and 8th of a cluster and has other houses back, left and right so they provide quite a lot of heat and insulation already
Does the house has economy seven elec?
I would be after some bod standard wall mounted storage heaters for mass heating I think, or if not on eco7, as said, you could do worse than an oil filled.
Daniel
One of these set to max and constantly on plus a programmable room stat wired away from the rad. You want 7 day, they only work to 24 hour cycles, hence the separate programmable stat.
Daniel
It'a not got economy 7, I've had it in the past elsewhere and the lack of control over the output was a right pain... especially when it ran out at night
