A bath shouldn't leak, unless your builder is cr@ap.prone to water leakage
It might give someone a nasty bang on the head as the ceiling below collapses.If leakage from the bath is enough to be a problem for the pump, the pump will be the least of your worries!
In any case what do you meanA bath shouldn't leak, unless your builder is cr@ap.prone to water leakage
These things can happen.i am thinking of the times when water leaks out from the bath because someone forgot to turn the tap off and water overfills the tub. or when water leaks down the side where the bath seal has become damaged and needs replacing.
the builder says he is going to spur the pump in the hot water cylinder cupboard which also lies in the bathroom,
But the floor and/or ceiling of the room below will fall down from water damage before the pump is affected.
Will the circuit you provide for the pump have an rcd?
i am worried that the person in the bath would get an electric shock from the water getting into an electrical item placed under the bath.
a leak from a faulty or old bath seal will make the wall damp and would take a while to damage the wall if not fixed.
overflow of water over the bath tub would soak the floor but may not do serious damage if it is stopped quickly. but an electric shock is instant and can kill immediately.
the flat is on the ground floor and so is the bathroom so it can't fall through anywhere. At least i don't have that to worry about.
Being pedantic, he can do the work but someone will have to pay LABC fees (up to £400 in some places I believe) to notify it.If he isn't registered then he cannot do the work.
