Electric Shower
7 Jun 2007
Yorkshire
My electric shower is broken. I need to replace it but don't know what type to get. I have a combi-boiler. I'm on a limited budget. Help!
Consider a Triton with the same Kw rating as your old one.
You should be able to have it supplied and fitted for approx £200 + :D
How do I find out the KW?
It's a Gainsborough ES550 and was here when I bought the house last year. Help!
If it is a 7.2Kw then would it need rewiring to be replaced by a 8.5kw? But if it is a 8.5Kw then can I put a lower one on it?
A lower one would give noticably worse shower performance. You really need a sparky in to check and advise. There is more to it than just cable size, ie switch ratings, mcb ratings etc. It needs to be done right.
I would suggest that the electrics forum might be a better place to start :wink:
