I want to do some pre wiring ready for an electrician to make the final connections on my UFH.
I am hoping that it will be suitable to use a nearby mains spur using a 30amp J-Box with 2.5mm TE running to a FCU (or RCB/FCU combined, it's an old fashioned fused box unit) which will then connect to a relay and finally to the thermostat. Is this a suitable approach?
The floor mats will require approx 1kw/4amps for the area I'm covering.
