Hello all
I am in the process of installing electric underfloor heating (the film type for laminates) into a newly built conservatory, and all appeared to be going fine. I layed the mats, made the connections, and it appears that the mats are warming up.
However, when I was putting some bulbs into the wall lights, I was getting a tingling felling from the metal work on the light fitting. I put my meter on the metal work, and it was registering anything from around 1vac to 36vac. This only happens when the heating mats are on, when the thermostat turns off it disappears.
I have done a resistance check on the mats, and they are roughly what they should be, and today I am going to try connecting the mats up separately (4 mats in total). I did a continuity check from Neutral to Earth and get a tone, but I understand this could be normal. I assume there is some kind of leak, as if it was a short the RCD would of tripped out.
The lighting in the conservatory is using a fused spur on the ring in the conservatory, and not the normal lighting circuit for the house.
Anyone have any ideas, or any other tests I could try.
