Electrical supply to garage
5 Mar 2010
Moray
Hi all, I'm after some advice. Im in the process of building a house and the electrician has given me two options for running the supply to the garage/summerhouse.
I have 30m of 10mm SWA that I purchased from marketplace in order to run a connection to my garage and summerhouse. My garage has a 7Kw EV Charger, solar/battery and the usual sockets/lights.
My summerhouse has a 32a hottub and sockets/lights.
My electrician has given me 2 options, use the 10mm SWA I have and run 2x circuits direct from my CU or run a 16mm SWA from the box directly to the garage (using a dedicated fuse unit and Henley blocks).
I'm just after some advice as i want to do it right but also keeping in mind budget. Thanks.
P.S Just to be clear, I will not be doing the work, just running the cables through ductwork along with the cat cables for CT clamps.
What's the distances from the house CU to the garage one and from there to summerhouse.
