- Joined
- 29 Nov 2005
- Messages
- 34
- Reaction score
- 0
- Country
Guys..I have already asked this question on another forum, but would appreciate any other opinions..
I have a new house in Thailand and just need a little advice/info. Basically the live and neutral socket connections are reverse ie live is neutral and neutral is live, as compared to UK. Details are
The incoming cables (240v) feed in via an 80amp Mitsubishi Supply Breaker.
This breaker has two outgoing sets of cables L&N) one to the Dist Bd supplying the breakers which supply the Air Conditioning Units..no problem here.
The other to a SAFE-T-CUT breaker 63amps with setting selections of 5mA, 15mA, 25mA and direct. It says that the tripping time is between 20mSec and 30mSec (not selectable) so is compatable with UK standard of 35mA for 30mSec I think. This feeds the dist bd. which supplies all the house power and lighting circuits. Each circuit has a circuit breaker. So this far is of a simular standard to the UK I think.
The wall sockets (power sockets) are rotated 90Deg clockwise compared to the UK. The pin which would be the neutral in the UK (ie now at the top) is actually the Live and the pin which would be the Live in the UK (now at the bottom) is actually the neutral.
Therefore if I plug in a UK appliance (via an extension lead, you can now get these that accept a UK plug) then the live comes in via the neutral pin on the plug and vice vercer. So the live is not fused.
The house is earthed via an earthing rod (simular practice to some older UK houses). Having and earth is now modern practice in Thailand although many appliances come as two pin. So it is belt and bracers 'I hope' (earth leakage plus circuit breakers).The house is on a garded complex' and was built by a reputable company. We bought it built so I supplied nothing.
More strange, I purchased, from the same shop in a Mall 'big store' a Electrolux washing m/c and an Electrolux fridge/Freezer. The indicated convension on the plugs was UK convension on the Fridge/Freezer and Thai Convension on the washing m/c ie live and neutral different on each. No fuses on either plugs.
This is ok or not please
Also could someone give me info on what I should ask the company about the house earth, resistance values etc
