- Joined
- 27 Jan 2008
- Messages
- 27,408
- Reaction score
- 3,309
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Reading the very scanty instructions for the 3KW inverter it should close down if overloaded. But I am not so sure when a ELI meter puts a load on the system to measure ELI. Can this damage the inverter?
All UPS systems must be the same, but at the time I worked with inverters and UPS no one really considered the testing with a ELI meter so not sure what the results would be?
Also since power out is so dependent on battery state, although it may pass all tests with fully charged batteries, once they are reaching the cut off point can they still open the protective device? Or would it shut down on electronics and re-energise each time fault is removed?
The RCD is also a worry with the wave form produced will they trip? Especially again when voltage may be low?
This article does talk about UPS but really it does not come under 17th Edition anyway. However I would still like to see some protection. Others must do the same, and I would hope there is not need to re-invent the wheel and some one has done it all before?
I have looked at 551.4.3.3 and the R ≤ 50/Ia would be satisfied if R1 + R2 is less than 1.9 ohms which I am sure it is.
However seems prudent to ask in case there is something silly I have missed.
