I have just replaced my hot water tank with a 210 litre one that is heated by indirect wood burner and a direct pumped oil fired condensing boiler. (ie it has two coils) My calculations show that its cheaper to heat the hot water overnight with off peak electricity (2p a unit!) and the tank has space for an emersion heater in it and I'm on the off peak tariff. So I am trying to work out how long the emersion needs to be on or what size emersion heater to heat 210 litres of water to 60degrees. Where are the calculations?
