Enforcer v10 pyronix
3 Sep 2019
I am trying to find out if I need to run a separate cable per wired keypad. I am currently running all back on one cable to the enforcer and going in to the terminal using only the one cable for the 3. It's a big job so not fired the panel up yet to find out if it would work but am looking for any info before I go too far and need to run another 2 cables back?
TIA for any help
You can daisy chain the keypad cable ...from keypad to keypad ....the only problem with this method is if you have a problem with the cable at a later date ...
