hi, not a major problem more an anoying nuacance
i have a 94 m plate escort 1600 zetec petrol injection engine
whatever the weather it starts first turn of key and has behaved normal ,tickover etc and run ok
but a gremlin has crept in since the freezing weather we had few months back
it now starts as allways and given a few revs warm up etc and ticks over as per norm
but at first junction 300 yds it cuts out
starts ok again and ok rest of day
i put a new idle control valve on i had , no change
this was followed by new plugs and ign leads
then mass air flow sensor
lambda sender
inlet air temp sensor
throttle position sensor
coolant temp sensor
new ignition coil last year
i cant find any leaking air pipes/hoses etc
its had a new petrol pump ,tank, filter, within last 2 years
so ive ruled out fuel problem as it starts up again no trouble
as i say annoying more than anythink
running out of ideas any help /advice as to where to look next would be welcome
cheers. r.r.
lambda sender
coolant temp sensor
cheers. r.r.
