Hey there,
I have had a corsa for about 7 months now, everything was fine untill my engine management light stated flashing on, but then would go away and come on every now and then.
Took it to the garage and they apparently fixed it (fitted a new pisten or something) yeah ran ok for about two days then the light came on and stayed on, and it actually broke down and wouldnt start.
Took it to a different garage this time and had a new air flow metre, and cam shaft sensor fitted, and it was driving ok.
The light was still coming on, I thought it may be because I had a small hole in my exhaust, so I had a new one replaced at the garage.
I thought I had actually sorted it now, but suprise suprise a couple of weeks later the light occasionally is coming up briefly and then turning off.
The manual says to diregard the light if it only comes on briefly but.......
Something is clearly wrong as when it comes on the engine seems to
loose power. It happens the most when Im doing 45mph and over, or when Im going up steep hills.
ANYONE HAVE ANY IDEA OF WHAT THIS COULD BE????
COULD IT BE THE ENGINE MANAGMENT CHIP???
ANY HELP IS APPRECIATED.
From frustrated girl with a nauty corsa x
