    Dismiss Notice
Engineered wood floor over ufh with a hotspot
Discussion in 'Floors, Stairs and Lofts' started by samtheplan, 12 Apr 2013.
  1. samtheplan
    samtheplan
    30 Aug 2011
    5
    Thanks Received:
    Berkshire
    Country:
    Hi
    I have an extension with wet underfloor heating. I am currently running up the ufh in preparation but have a hotspot where all the heating pipes convergence into the manifold.
    The majority of the floor is at 25 -26 degrees but the hotspot is around 30-32degrees.
    I know the rules about having a max temp of 29 degrees so how can I get around this.
    Is this an absolute rule? Can it be bent or will the floor suffer. Is there some sort of very thin insulation layer I can isolate the spot with? Am I going to have to turn the flow temp down and maybe have a cold house?
    Any ideas comment welcome.
  2. WoodYouLike
    WoodYouLike
    14 Nov 2004
    7,710
    Thanks Received:
    215
    Kent
    Country:
    How "large" is this hot-spot?
  3. Sponsored Links
  4. samtheplan
    samtheplan
    30 Aug 2011
    5
    Thanks Received:
    Berkshire
    Country:
    The hotspot is approx 50cm x 20cm within a meter wide corridor that is approx 2m long before opening up into a larger room. It was almost impossible to avoid bunching the pipes at this point. The boards will run length ways from the room into the corridor. If there was a door frame I would break the floor and just fit it as if there was a problem it would only be a 2m area of problem. As it links through I'm a bit worried
  5. WoodYouLike
    WoodYouLike
    14 Nov 2004
    7,710
    Thanks Received:
    215
    Kent
    Country:
    It also depends on the quality of your wood-engineered boards, especially the quality bonding between top-layer and backing.
    For instance, these products are highly suitable for UFH and could tackle the hot-spot - as long as you treat your UFH normally and don't exceed the maximum temperature on other places than your hot-spot
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
