I've started demolishing my fireplace (old open fire in 60s house) with the intention of rebuilding it using new bricks, wider than before.
Here's a top-down section:
I'd like to rebuild the inner skin of bricks 1 brick wider on each side, to accommodate a log burner.
My worry is that I might find it impossible to remove the existing bricks without compromising the load bearing capacity of the wall. 215mm worth of bricks each side need to go.
Is the inner leaf of the recess likely to be supporting anything further up the chimney?
The first floor joists are bearing down on this wall too, if I remove a 1.1 metre width section of bricks am I likely to destabilise things?
Here's a pic of my progress:
I can see that the centre two columns of bricks are fine to remove, but the sides may be a different story!
Thanks!
Thanks!
