I plaster competently. I prefer using large floats (where I can) my favourites are 16, 18 and 20 inch marshalltowns. But I can't find a large hawk to lay on with a 16 or 18 inch easily.
My current (nice!) hawk is a 14 inch magnesium marshalltown, but it feels very small and restrictive (I can't really lay on with a serious trowel with this). I see 16 x16 inch ones are out there for sale but my eyes lit up seeing reference online to a Kraft Tool Aluminium Offset Plaster Hawk 20" x 16", and a similar marshalltown 212p hawk- large aluminium plasterers tradesmans hawk with adjustable DuraSoft handle. Size: 500 x 400mm (20 x 16in).
Both are discontinued, but I'd love to try one. Has anyone got one they are getting rid of, or old stock, or something similar they know of? Or indeed any observations as to how to lay on with a large trowel easily?
The increase in speed with larger floats is better than simply the apparent increase in size (same logic as paint rollers). The useful width of trowel is its width minus the overlap between pulls, so if you overlap 2-3 inches a 10 inch trowel only has a useful width of 7 inches : but a 16 inch trowel has a useful width of 13 inches : it's nearly covering double the area per pulland means you have literally half the number of lines left on the wall after each dry or wet trowel - not what you'd imagine. It's why 18 inch paint rollers obliterate silly 12 or 14 inch ones for speed.
Why large floats ? You cover larger areas faster, increasing what you can do in one hit, but most importantly : higher quality finish, as the "Average distance between ripple peaks and troughs" is determined by the size of the trowel, hence you always want to use the largest you can, similarly use the longest straight edge for pulling in ceiling lines/ corners, screeding off etc. Half the reason DIY plastering often ends up looking rubbish is because they're playing with 8 to 10 inch trowels, which have their place when work space is limited, but not for a wide open wall of ceiling. Hence you need of course a range of floats in your armoury from as large as possible, covering all sizes down to "a small tool".
