EPC came back lower than expected – what actually moves the rating?
24 Nov 2026
Hi all, landlord here in Birmingham, and I could use some advice from people who have been through this.
One of my properties was reassessed recently and the rating came back lower than the last one, even though nothing much has changed. The assessor was in and out in about ten minutes and did not check the loft, so I am not sure how much weight to give it.
For those who have actually improved a rating, what made the biggest difference for you? Loft insulation, draught proofing, heating controls, or was it just different assessor assumptions? And has anyone asked their assessor for the improvements list in EPC points order and found it useful, or is it just a generic list?
I am trying to work out what is worth spending on first, before I pay for any work.
When i moved into this bungalow i had an EPC of D with bad insulation, crital-windows & electric heating. Since then i have doubled the size with new insulation, double-glazed windows, doors & LPG heating, & i have now gone down to a E. I called them up & asked why. The square meterage had doubled & has to be heated, meaning loss of energy. "Cant win" If I hadn't insulated & had new windows, it would have gone down to F or G.
Nowadays, they want to see solar & heat pumps to get a better rating & you will be lucky to get your money back with those.
Surely your report tells you which features scored low, and what could be done to improve them?
Does it accurately say what loft and cavity wall insulation you have? And if your windows are double glazed? And if you have a condensing boiler, with good controls?
Tells me all of that, but my biggest downside was the amount of area that needs heating now compared to before. And heating is one of the biggest offenders of energy.
To sell a house it needs an EPC, but when I looked on line, my house already had one, I had been there since it was built over 25 years, and had never paid for an EPC but there it was on line.
Clearly no one had been in the house, all they could have done was view it from the outside. So it seems clear very little value to an EPC.
This house, there are far too many assumed against findings, and last house clearly all assumed, I know when we went to have cavity wall insulation, it was found already to exist in the extension to kitchen, and this house, for some reason there are two reports, one for the flat under main house, and one for the main house.
So which is deemed to have solar panels on it, and which is deemed to have batteries and inverter, not been done since added.
So 1795688547911.png1795688591241.pngtaking the hot water so 6,778 kWh in total, I have iboost+ so in the summer it records how much used, Saved last 28 days Tuesday 4th Aug 26.jpg there are 13 months in a year, so 807 kWh per year, that's a factor of 8, the EPC says I am using 8 times the real figure.
As to heating at around 10p/kWh for oil, £1,800 is a bit higher than the real bill, by a factor of around 2, but the EPC done in 2018, when oil was a lot cheaper, so again way out.
As to the list to improve it, Floor insulation (solid floor) 104 years pay back time, Low energy lighting 1 year pay back time, Solar water heating, 84 years pay back time, well since I now have PV solar it would never pay, as water heated with excess PV. Solar photovoltaic panels, 2.5 kWp, 26 years pay back time, since I now have 6 kW of solar panels I know my bill has dropped from £130 a month to £130 per year, so it will take around 6 years to pay back, but with such daft figures, really what's the point?
Who in their right mind will fork out for some thing with 100 years pay back time, and that's first on the list. Nothing about double glazing, we have had all the old double glazing replaced, and that has really helped, but nothing in the EPC to suggest that, also one side of loft has more insulation added, and other side floored over the orignal insulation, again nothing in the EPC report.
The flat under main house Step 2: Hot water cylinder insulation well it does not have a hot water cylinder, that's in main house, Step 4: Hot water cylinder thermostat again it has no hot water cylinder, it's in main house, Step 5: Heating controls (room thermostat) well on moving in, only the flat had a room thermostat, it was the main house where it was missing, so it seems they walked around in a dream?
Its because the goalposts are moving.
My mate is a landlord and had 20 year old UPVC an old upvc front door and a 35 year old boiler and hot water tank. His EPC was a C with (can't remember exactly ) lets say 89points
Then he put current spec UPVC windows in and fitted a condensing boiler and a composite door. Then time came for a new EPC and although it was still a "C" the points had gone down so it was given a lower rating despite all the changes.
Also the government are changing the EPC ratings structure so that a house with a gas boiler will NEVER acheive a C rating, added to that come 2030 if you do not have an EPC of C then you will not be allowed to rent it.
The EPC rating is almost 100% dependent on the assumptions the Assessor makes, especially when he cannot be bothered to do a proper inspection of the property. He just feeds quick answers into an algorithm on his tablet computer and out pops an EPC rating. This rarely bears much connection with reality and the EPC rating is therefore pretty much worthless, but the politicians are busy framing laws around this nonsense.
An interesting situation will arise when it becomes illegal for landlords to let out a property if its EPC rating is below "C". If the landlord has sitting tenants then presumably he'd have to evict them to stay within the law - but evictions have been also been made illegal without a protracted court process. So presumably the only course of action for the landlord, if he wants to stay within the law, is to let his tenants stay rent free as "guests"!
The government are heading into a complete mess with this. NO home with a gas boiler will be allowed to acheive a C its completely mental barmy.
Sitting tenants may not trigger it but once they leave then the house will be sold and not re rented, currently there are 2.41 million private rented homes that do not reach a C then add to that many more millions of homes that will fail to get a C because they have a gas boiler.
I'd sort the evidence side before spending anything.
A ten-minute visit with no loft check usually means the assessor used default assumptions. Defaults are nearly always worse than reality.
Dig out what you've got. Loft photos with a tape measure showing the depth. Cavity fill guarantee if there is one. Boiler model and install date. Receipts for windows or heating controls. Send it to the assessor and ask them to re-lodge. If they won't, you can complain to their accreditation scheme, which is named on the certificate.
The calculation method also changed last year (RdSAP 10). Some properties moved a few points with no physical change at all.
If you do need to spend, the cheap wins are usually:
- Loft topped up to 270mm
- Full heating controls: programmer, room stat and TRVs
- Cylinder jacket and thermostat if there's a tank
- LED bulbs throughout
On your last question, the recommendations section isn't just generic. It shows the expected rating after each step, in order. So you can see exactly which measure tips you over a band. Ignore the payback figures though, they're often way off.
My mate did all that with the assessor, got nowhere.
Changing the lightbulbs doesn't help because the tenants can still put in an incandescent on. Its the actual fitting that has to be changed to a fixed LED one to get you a couple of points.
