I've decided to do a small flat-roofed canopy over a front door in EPDM. There seem to be two types of adhesive, water based and contact (I think?).
The adhesive will be used to bond the EPDM sheet to the ply roof surface, ply on the the sides where the EPDM turns over and down the edges/sides and a thin ply upstand where roof meets wall (this will be flashed).
As it's such a small roof, and the adhesive is only available in very large tins, can I just buy one type of adhesive for the whole job? If yes, which one - I'm thinking the contact? Can the contact be used over the whole of the ply roof surface?
Is there anything else I need to bond the sheet to the roof? I will be using poly nail trims on the edges and either a lead flash or screw on sheet metal version. Many thanks.
