Immersion element kapput on my cylinder. The lower one (11"). I tested the stat and it was clicking on n off, so definately the element that has gone.
It's fitted on an Essex flange.
Borrowed a heptagonal box spanner to loosen the immersion but only succeeded in loosening the Essex flange. The Essex flange clamping nut is approximately the same diameter as the immersion BUT it is hexagonal not heptagonal.
Are thin hex spanners available for Essex flanges? I can then perhaps lock the flange nut while I work away at loosening the immersion??
The Essex flange I have worked loose enough to possibly but also very carefully grind off the front and if I have to fit a new flange; so be it, especially if it turns out to be too much like hard work with no garauntee of succes in loosening the immersion.
Is this a common problem???
I really dont want to have to go through all this againg 10, 15 20 years down the line when the damn thing goes again
Also no drain off fitted and no timer fitted.
I've already fitted a drain off but any suggestions regarding fitting a timer next to the cylinder would also be appreciated.
Is it OK to remove the fuse holder, put in a 1 gang socket and put a segment timer on with the immersion lead into a 13 amp rated pulg?? The missus keeps forgetting to turn the damn thing off and it must be costing us a fortune.
