Hello all,
Our evo he c22/30 has decided to stop working, and not he best time of year to do so.
The boiler will not turn on, i have checked the fuses on spur and in PCB and used a tester to see if power was getting to the boiler which it seems to be, and also to PCB, the manual says if "0" is not shown on user control panel then not a boiler fault, but not sure how true that is.
I have only just repaired the boiler 2 months ago when the DHW thermistor needed changing.
I am unsure if the user control panel display is broken if this would cause the boiler not to work or if PCB is broken.
Any advise would be great, thank you for your time
