Ext Hardwood Door 73 x 198cm not veneer
15 Jun 2004
Norwich
Looking to replace my Front Door.
Apart from getting one made anyone know where I can get this or slightly bigger than can be cut down
If it's a Victorian door or similar, try a reclamation yard.
You may also be able to find what you're looking for on eBay.
No its not Victorian. I have found doors that are about 32mm to wide so I think that may be ok.
It depends on the door construction. Normally taking 16mm off each side will leave you with a door where the stiles look a bit narrow, but you may find that the tenon wedges need to be replaced when you make such a deep cut. What does the manufacturer say?
I make that about a 29" door, is that right?
30" is the next nearest common size.
is the old door a tight fit in the frame?
The current door is a nice fit.
I will ask the supplier the question you suggested. Thanks.
