Extending a chrome flush pipe for a WC
27 Oct 2006
London
I've just bought a traditional low level cistern for my WC pan, and now trying to find a chrome exposed flush pipe to connect the toilet to the cistern.
However, the back of the toilet pan is 350mm away from the wall meaning I can't find a standard chrome flush pipe long enough to connect between the cistern and the pan! (WC pan is cemented into a basement floor and so I don't want to touch it)
The 2 ideas I have are as follows:
1) use a chrome bath waste pipe with a 90 degree bend. I managed to find one that is 300 x 600mm x 38mm
2) use a standard low level chrome flush pipe, and try to extend one end of pipe to reach the back of the pan. However, I can't find anything I can use to extend it by about 80-100mm.
3) make a 80mm deep stud behind the cistern to bring cistern closer to the pan - but really don't like this option as will look pants.
Any ideas / advice much appreciated as always.
Another option, is to buy a high level chrome flush, and cut out a section of it, where one pipe joins to the other and add it into the end of a low level flush pipe.
This will end up quite an expensive flush pipe though
