I have a small chimney breast in my new house - more a flue than chimney. It
is only 1 brick deep from the back wall, but unfortunately its not in the
middle. As i am putting an LCD on it i want to make it look central to the
room. I am planning to extend it to one side by around 250mm using stud
work/plasterboards/plaster.
The question is do you build it such that on the outfacing wall the stud
work is flush with the current plaster or (as i think you would) do you
build it such that its ~3mm back from the current plaster line such that
when its plastered its much easer to jet a seamless join?
A pic of what I am looking to do is at
http://www.convery.me.uk/temp/ChimneyBreast.jpg (Red = addition)
.... The best suggestion I have had so far is....
To me this does sound like the most sensible. If I were to follow that attack is there a specific way to attach PB to a brick wall - the one i have seen most often on TV is using 'dolops' of plaster at regular intervals.
Is that the right way to do it?
Make it flush, and fasten a sheet of PB over the whole face,
including thge existing breast - with a little thought you
can make shallow cupboards or shelves in the side. If you
just make an addition and skim the lot flat, you are very
likely to find a crack develops at the join.
