Extending toilet waste pipe
1 Apr 2013
Norwich
About to fit a new toilet and I have found the waste pope to be a tad bit short. Any advice on how to extend? Im playing dumb here because its my first time dabling with plumbing. Also i presume the toolet waste exit should be slightly hire than the main waste pipe? Thanks.
If you mean extending the white pipe it's a flexi so it will just pull longer.
If you want to extend the grey remove the inserted pipe and add a longer piece
Sorry I meant that the flexi needs a bit more extension. At this moment in time, the flexi is at its absolute limit and I dobt really feel comfortable with that
Bent flexi or use a piece of soil pipe in that socket joint?
Don't use a flexi, you look like you've enough room to get it all done in rigid 110mm pipework unless there's something unusual about the toilet itself?
You can get right angle flexis longer than that, or extend the rigid pipe and use the existing or equivalent new flexi.
