Hi all,
I need a lot of guidance and hand holding, finishing off the drainage outside new extension and patio prep.
We want to build a patio, side fence to fence to finish just below the bottom of the air bricks, its around 300mm from current soil level to desired finish level.
I understand I need to build a retaining wall (red lines) to build up to this level - first bit of guidance needed for this please.
I have a lot of hardcore as well as a lot of soil, however my understanding is I cannot use the soil to back fill as it will sink over time?
What do I need to do with the drainage, as you can see the guttering down pipe is not connected to the soak away drainage yet? (soak away is in place further down garden and pipe to meet downpipe is in place).
You can also see that the drainage from the kitchen hasnt been completed yet.
Do I need a threshold drain running across the back of the extension (blue line) and if so how do I complete the kitchen drainage and downpipe to soak away as it will be sitting right in the way?
Sorry for stupid questions, this was a 50% DIY build, hence the in completion.
https://freeimage.host/i/JE4yFaI
