your plans are as clear as mud. By the sound of it, you haven't a clue what your power requirements are and you dont know a right lot about circuit design either . . .
for starters, 6mm² will have trouble fitting into a socket, never mind a light. And outdoor cable runs must be protected, normally by running armoured cable and terminating in appropriate glands.
Lynda, Crafty is totally correct, the wiring has to be mechanically protected and the circuit must be protected by an RCD. Unless you are competent in electrical installing it`s best to get a professional in.
