Hi All,
I have an odd situation where my loft waste pipe for the toilet runs close to the roof as it exits the wall. I need to do this so the toilet isn't too high in the loft. Because of this I can't get a branch over the eave in order to run the pipe above the roof line. I have sketched up a run using 90's but then breaking into the horizontal section and adding an air admittance valve.
Can anyone advise if the proposed sketch below is suitable?
Not to scale, all minimum falls assumed, admittance valve noted but not sketched in.
Thank you.
Thank you.
