Hi All,
I just wondered if anyone could give some advice on running power from my consumer unit to an external Tortoise enclosure? I am a bit of a noob with electrics.
I have a Wylex NHRS6604 unit that is a 12 way split load. Configuration is 6 +6.
Link https://uk.rs-online.com/web/p/consumer-units/0424683/
I'll be putting probably 2 x 100W Heat lamps and a couple of UV strip lights on it.
The consumer unit is at the other end of the house, we have external insulation around that stops at around 6" from the ground. I was thinking of coming through the wall and running along the underside of this in some sort of ducting if that's OK to do?
Could anyone advise on what to look out for hazard wise and sort of kit would be most robust for this. Ideally good value but Tortoise comfort > Lowest Cost.
