Hi folks,
I've had a search about but can't see that anyone's asked this already - apologies if they have and I've missed it.
I'm having a new external garage built, and want to run the cable / do the first fix myself. I have a spare way in my consumer unit, so would like to run SWA from the house Consumer Unit under a lawn (probably a spade and a half's depth, perhaps with a edging stone or something over the cable to give it extra protection). My question is how do I bond / terminate the earth of the SWA to both consumer unit's:
- is there a special connector inside the plastic enclosure?
- do both the CPC/Earth and the steel wire shield attach to the neutral bus bar?
- is there a special consumer unit / enclosure to use at the Garage end (I've been looking at the MK Sentry 4 way at Screwfix for about £40 - but can't see anything in the description about SWA termination?)
The garage only needs a few sockets - no heavy loads, and lights (although there will be two external lights - one of which will be a lamp post a few metres away so will have a second SWA run to that).
Hope someone can offer some advice.
Cheers
Don
Cheers
Don
