Hello:
The expansion vessel on my central heating is faulty - the water pressure is all over the place when heating and it keeps opening the pressure release valve. I went to re-charge the expansion vessel but water came out of the air valve, indicating the bladder has failed.
The boiler is in a difficult to reach location and needs removing from the wall to replace the vessel, not only can I not do this, but I estimate a bit of collateral damage to the surrounding kitchen space due to the tight git and location of the boiler.
There fore I am hoping to simply ignore the failed unit and add an external expansion vessel to the CH system to fix the issue, there is no-where convenient next to the boiler to site the second unit, so am hoping I can pout it somewhere else - under the stairs where both the flow and return pipes run would be really easy and convenient and out of sight.
Some advice says the should be near to the boiler on the return, but this is really not convenient - is my suggested location OK? (approx halfway around the CH circuit)
Thanks - IcarusBop
Thanks - IcarusBop
