External porch lights - what's wrong with this picture?
Who sleeved the blue brown?
So the first electrician did the main wiring, then disappeared - didn't bother with any sleeving, etc.
Second one I got in to sort out the first mess did the sleeves.
Am I right about the 3-core not being needed externally and just to use any two wires?
Ok as long as you're sure.
Yes.
Well considering the wiring still doesn't seem right, me being sure they did the work isn't worth much. :cautious:
But why do you ask? What difference does it make?
So this works:
And for all the world it looks like 1.5mm T/E for the lighting loop, 1mm 3C+E used as the switch drop cable, brown permanent, black & grey switched.
The blue at the switch can't be N, or exciting things would happen when the switch was turned on.
