External porch lights - what's wrong with this picture?
26 Sep 2025
Hi everyone,
Back again with some gremlins courtesy of two electricians who have been unreachable since they did the work.
The below diagram is for a two-gang switch. One for the internal porch light (which is fitted and works fine) and the other for the wiring for two external porch lights. These have apparently been tested by the second electrician but when I tried to wiring an external lamp today I couldn't get it to work.
Welcome any thoughts/ suggestion please.
What the light rose wiring looks like for the internal porch.
Is there a neutral in the switch?
If im getting it right you have a twin and earth from the switch to the light then a 3 core amd earth between lights for some reason.
Arr ok the black and grey are in the same terminal in the light and in the switch (I think)
You'll have to use one as a neutral and join it to the blue in the switch and link the coms together...
Make sense?
And a 3C+E at the switch.
Make sense?
Not to me, who is seeing that the blue in the switch is in a switch terminal and sleeved brown...
Make sense?
Do you mean this?
All wires at the switch​
WireExisting connectionNew connection
Left brownLeft COMLeft COM
Right brownRight COMRight L1
BlackLeft L1Left L1
GreyLeft L1 originallySeparate neutral connector
BlueRight L1Separate neutral connector
New brown linkNoneLeft COM to right COM
Earth wiresEarth connectorRemain joined, with appropriate earthing of the switch and back box
Neither L2 terminal would be used.
Changes at the internal ceiling rose​
The grey wire is currently connected to switched live at the ceiling rose. In the new arrangement, its function would change to neutral.
WireProposed function
BrownPermanent live supply to switch
BlackSwitched live returning from internal switch
GreyNeutral supply to switch
The grey wire would require blue sleeving at both ends, and the brown sleeving on the repurposed blue wire would need to be removed.
The 3-core and earth outside is still unresolved - just need to use two of the three + earth?
