Hi all
I'm having the exterior walls of my whole house rendered. The existing render has been removed down to the brickwork (which is in bad shape). The new loft gable wall has the thermalite blocks and the new ground floor extension has the dense concrete blocks.
My builder will be doing a scratch coat (sand and cement) first and then will do the second coat of sand and cement with a pebble dash finish.
I want to insert a fibre-glass mesh into the middle of the scratch coat to stop cracks appearing in the future and was planning on using the pink BOND IT RENDER MESH from selco.
Can I use this mesh for sand and cement?
Or is there a better one that someone can recommend?
