Hi
I thought I should open fresh thread for this question. I had a problem of 3 sepaarate leaks in radiator pipes bedded in a concrete floor. It started after a power flush and although everything has stayed dry for the last 3 or 4 weeks, I have lost confidence in that pipe work so want to replace it.
We have an open vented system with header tank in loft and hot water tank upstairs. The boiler is downstairs and the pipework goes upstairs to the hot water tank cupboard (where the pump etc is located) and then runs, amongst other places, back down to downstairs rads.
I was thinking I could replace the run to the three rads downstairs (currently fed under concrete) by installing flow & return pipes from an upstairs bedroom rad, through the floor/ceiling and down the wall to the downstairs rads. I am happy to box them in. But a plumber said that it wont work, and I cant run pipework up and down. I dont really understand that as the pipework already runs down to the downstairs rad circuit. So I will just be running down in more than one place.
I would welcome any suggestion/advice - thanks
Graham
Graham
