I need to fit a 3m run of ducting for my bathroom extractor fan. I have been advised not to use the plastic flexy stuff as it will aparently reduce the extraction rate and instead use solid stuff. Can I use standard 100mm soil pipe for this? If not where do I get the correct ducting from?
Note that the fan is a vent axia ACM100T. The spigots have a outside diameter of 96mm.
