F&E tank for a megaflo?
16 Apr 2008
Bedfordshire
Had a couple of plumbers around to give me a quote for a megaflo. One plumber mentioned that I would need an F&E tank for the heating particularly as one of my options is to retain the old boiler but the other plumber said nothing about it and it does not appear on his quote.
Does a megaflo need an F & E tank fitted for the heating in all cases or only if an old boiler is being retained? If not where does the expansion go?
If the old boiler cannot be a sealed system then yes youll need to keep the F&E tank
So a sealed system keeps the CH pipe work and radiators under a higher water pressure which is relieved by an expansion vessel then or have I got it all wrong? Is it a bad idea to seal an 18 year old boiler that used to be open vented?
Yeah not a good idea mate unless ya gonna change the boiler and another weak spot will be the rad valves !!
It may not be possible to go sealed system on your boiler. It also makes no difference to a megaflow wether a boiler is open vented or sealed system.
Do check that the fitter is qualified (Ask for his card) to fit a Megaflow. While it is not difficult to instal a Megaflow, unqualified person may not be aware of needs or requirements of fittings and pipe sizes.
