Hi there,
So I have learned a lot about my plumbing over the past few weeks after discovering the float valve in my Cold Water Storage Tank was faulty (gushing out the overflow). I came across numerous helpful threads on this forum & I now know the difference between the CWST & the F&E header tank & generally how it all joins up!
Anyway, since the float valve in the CWST was replaced, it got me thinking about the overflow in the F&E header tank. From what I can see, there is only 1 single overflow pipe (coming out the roof eaves), which is connected to the CWST only. I noticed on some forums, many people suggest the 2 are occasionally linked (one-4-all overflow pipe) or in some older setups, the F&E tank overflows into the CWST then continues out the CWST overflow (which is not ideal).
I had a nose around the F&E tank & I actually cannot for the life of me see where there is an overflow pipe coming out of it full stop. It seems to have 3 pipes going into it, which I assume (again from reading over forums!) that they must be:
* Mains water feed (at a low point in the tank)
* Flow pipe to boiler (I think relatively low but at a higher point)
* Vent pipe to boiler
The tank is in a rather awkward position, which is a shelf adjoined to the roof joists/rafters directly above the CWST, but from what I can see, there really doesn't seem to be any sort of obvious overflow.
There is a inverted "U" shaped pipe leading into the top of the CWST but I presume this is the vent/expansion pipe for the Hot Water Cylinder & unrelated to the F&E tank?
Would I be correct in assuming because the water main enters low down in the F&E tank & it's the highest point in the house where water main travels, it cannot (due to gravity or some such) fill any higher than it's highest point? Thus cannot overflow? Or is that absolutely not the case & there absolutely should be an overflow?
Sorry for the waffling above but trying to be as detailed as I can in the first post.
Just again for clarification, the F&E tank is above the CWST & the mains cold seems to T into both of them.
Any thoughts appreciated!
Ash
Ash
