falling pressure in sealed system
31 Jan 2005
I have a Worcester R28 System boiler, only about 2 months old. It has an integral pump and diverter valve so has two separate loops, one for the indirect hot water tank, one for the radiators.
I replaced most of the radiators from the old system and did most of the new pipework around the boiler. A corgi plumber checked it and commisioned it for me as well as powerflushing the old pipes.
Every week I have to add more water as the pressure drops to below 0.5 bar, when it starts at 1-2 bar.
I have checked all the connections I can and haven't found any leaks.
Does the air vent on the expansion vessel need to be open (it is)?
Could the water be evaporating from somewhere without dripping?
Should I disconnect the filling loop?
There is a quirk with the hot water taps as they splutter like there is air in the pipes. Could this be a clue?
Hope you can help.
Thanks,
Gary
Keep looking.
Check the pressure relief pipe through the wall isn't wet.
Does the presure go down while the boiler is not being used?
Yes. SOmetimes they're moist but don't let that much out.
Yes. Rad valve stems typically.
Certainly.
>There is a quirk with the hot water taps as they splutter like there is air >in the pipes. Could this be a clue?
No. Indirect system not a combi. That's just bad plumbing!
thanks for the reply!
Will try and turn it off for a while see if it drops still.
Will check joints again.
Have now disconnected filling loop.
Bottom connection to HW tank was leaking when I first turned it on. Quick tighten of the nut stopped it. Will tighten it a bit more.
