Fan Assisted Oven
24 Nov 2003
Just registered on this site and I'm in need of a bit of help... :wink:
I'm looking to install a Fan Assisted Oven and I have been told by some that it can go into a 13Amp Socket :) but I have been told by others that it MUST be isolated and connected via 6mm cable and so on :cry:
Can anyone put me straight on this...
Ta...
P.S. If it can go into the Scoket - would it make a difference if it was a spur Socket :?:
Stay Crispy :shock:
ouir fan assited oven just plugs in to a normal socket, but then it is a gas fan assited oven.
If your is as ours (gas) then ordainiry plug is fine, if electric oven then no.
Thanks Breezer...
I suppose I should have said that it was an electric oven :oops:
As is it just an oven - the hob is gas - and the oven is just over 2Kw, can it be pluged into the 13Amp Ring Main??
Sorry to go on - but I need to make sure I get this right. :?
2kw yes it can be plugged in, you can plug in anything up to 3 kw.
but use a good quality plug
