Fan Capacitor
Ah. Thank you.
Being picky, as is my wont -
Can you interchange words which have multiple meanings, when one of each might coincide?
I.e. goosed = f**ked = had sex.
F**ked also = broken = goosed ???
"If it trips or fails then fan has had intercourse."
I suppose that's the dreaded evolution.
Every word will mean everything soon.
Saturday night, lots will get house sparrowed.
Not sure what that means but -
Goose would seem an illogical choice for a synonym of f*ck because it already means to grab someone's buttocks.
My point is - for example, prison officers are called screws, referring to them as sh*gs, bones, bonks, bangs, humps, f*cks or even fixings does not follow.
Goose would seem an illogical choice for a synonym of f*ck because it already means to grab someone's buttocks. ...
Doesn't rhyming slang invariably substitute a word that already has a (totally different) meaning (or meanings)?
Kind Regards, John
Yes, I am not quibbling that goose may mean f*ck in its sexual meaning if that is indeed the case in rhyming slang. I don't know.
To transpose it to also mean the other slang meanings of f*ck as well does not follow especially as it already means something else.
Well, it has so it's too late.
Do you not agree with my point about prison officers?
I think you may misunderstand the concept of rhyming slang. I don't think it has got anything much to do with meaning but, rather, is simply a 'word substitution' (think of it as a 'code' if you like), which arises because f*ck (with any meaning) rhymes with "duck", hence "goose and duck" which, per the tradition of Cockney rhyming slang, then gets abbreviated to just "goose".
I'm not so sure about that - see above. However, as for the second part of your comment, as I said before, Cockney rhyming slang, by definition, always substitutes a word which "already means something else". That's how it works.
I agree that one would not use alternative words to "screw" to refer to prison officers. However, it's not rhyming slang but, rather (as I understand it) its derivation relates specifically to prison officers, since "screw" once meant "key", and prison officers "turnkeys".
Kind Regards, John
I've already explained, John.
It's you who seems to be having trouble understanding tonight.
I didn't mention rhyming slang; you did.
Exactly.
So, the fact that 'screw' is also slang for other things does not mean that synonyms for those other things can be used for POs.
That's true - but I mentioned it because substitution of "goose" for "f*ck" IS rhyming slang - nothing to do with meanings, simply because "f*uck" rhymes with "duck"
Agreed - but, unlike the situation with rhyming slang (f*ck always rhymes with duck, no matter what the meaning of the former), there is no reason why those synonyms should relate to prison officers (those who 'turn the key {aka 'screw'}').
Kind Regards, John
What a pathetic place this forum has become, and it all started with the ridiculous arrogant waffling of JohnW2.
To the op, take safety precautions, turn on the power, poke the fan blade with a screw driver, if it spins replace the capacitor. If it doesn't spin buy a new fan.
does it? I didn't know that.
Is it a regional slang? Where from?
Or is it slang that has died out?
Yes.
I have no idea.
Obviously not.
Just to point out -
Rhyming slang uses a two word phrase, the latter of which does rhyme with the chosen word.
Apparently "Goose's neck" is rhyming slang for "cheque".
So, someone would say "Is a goose's alright?"
It is unlikely to be used for anything else.
The fact that duck rhymes with f*ck and, like goose, is a bird is not rhyming slang.
Why goose should have become synonymous for f*ck as in sex in urban slang, I also have no idea.
Read the thread.
For the record, "it all started" when Jackrae used rhyming slang to indicate that the OP's fan motor was probably dead, after which EFLI asked him what the word he'd used meant.
Kind Regards, John
Indeed, but what makes it difficult for those not-in-the-know to understand is that the second word of the 'phrase' (the word which rhymes with the word being replaced) is usually omitted.
But it is - not because duck and goose are both birds but, rather, because someone decided that "goose and duck" is a 'well known phrase". Many of the "two word phrases" are a bit contrived, and not necessarily 'everyday phrases' (e.g. "apples and pears", "trouble and strife" etc.).
People keep telling you. I'm not sure that 'synonymous' is quite the right word for slang, but the reason is that it's rhyming slang. And, as I've said, it is not restricted to "as in sex". If you moved in appropriate circles, you would probably hear people saying things like "What the goose?", "Goose off", "I don't give a goose" and, as in this thread, even "the fan motor is goosed".
Kind Regards, John
